Hello - here is a post I have been working off of for a while on the Dell forums about this issue I've been having - since this site offers a specific area for voltage changes I thought I might see if anyone had any thoughts on this.
I've included the SPEC sheet from Dell on the computer, but that is about as specific as I can get for information about the motherboard. I know it says that the max is 2 gigs of RAM but I had no problems running 2x2gig DIMM's without the PCI-e card. I think that combination of the additional card and two DIMMs is causing the issue, so could I run a single 4gig DIMM to reduce the voltage draw?
Dell Optiplex 320
Intel E2160 (Dual-core, 64-bit)
4 gig RAM (currently 2 gig, read on...)
160 gig HD
Video: ATI Radeon Xpress 200 (integrated) Radeon X1300 256 mb PCI-e 16x slot <--where the issue started
OP System: Windows XP 64-bit
BIOS: Latest 1.1.11
Drivers: All the latest, working no errors!
So basically when I installed the 2nd Radeon card in the PCI-e slot, I discovered that my computer ran miserably slow, or wouldn't boot at all.
Dell was no help, they though my motherboard was "bad". So they replaced it per warranty, which made no difference.
Finally someone suggested I try it with just one of the two, 2gig DIMMs I had installed, and it worked perfect: NO ISSUES except I no longer have my 4 gig of memory (which would help me a lot in some cases: ie. games)
Since I didn't have this issue prior to installing the PCI-e card, and was able to run both memory DIMMs I believe it has something to do with the way the system BIOS allocates resources between the RAM and the PCI-video bridge! Ideas, fixes, all will be considered!
Thanks!
From Dell:
Memory
Type
533- or 667-MHz DDR2 SDRAM
Memory connectors
two
Memory modules supported
256-MB, 512-MB, or 1-GB non-ECC
Minimum memory
256 MB
Maximum memory
2 GB
BIOS address
F0000h
Dell Optiplex 320
160 gig HD
BIOS: Latest 1.1.11
Thanks!
From Dell:
Memory
Type
Memory connectors
two
Minimum memory
256 MB
Maximum memory
2 GB
BIOS address
F0000h
