1 - 20 of 28 Posts
Lag with low ping in TF2. I've never had this problem before. I'm on a wired network with another computer downstairs. Usually only join games with 80 ping at the highest, even then before I never had lag even with large amounts of people fighting in an area. Now when I enter a high traffic area is lags pretty badly and really kills the game. I'm pretty sure it isnt spiking as I've checked with the net_graph up. Any help would be appreciated.
what are the specs on the computer? It could just be a slow PC.
its this one, I worded it poorly but I was just saying there was another computer hooked up to the internet but its usually idling or off when I play so it shouldnt matter, its not as if it's downloading things when I game.
are you sure its the network.
It might also be something inthe background constantly writing to the hdd like a page file or something.
Try it on other games thats single player, and if it does the same then its not network related
Discussion Starter · #8 ·
how can I gauge lag in single player?
well, not really lag, more like slowdown.
huh? It isnt FPS lag and the ping is steady at around 50 right now and its happening. It isnt spiking at all.
Discussion Starter · #11 ·
heres a pic, it usually lags around this point with people teleporting and rubber banding. Its not horrible but definitely hinders gameplay especially with a spy.
Discussion Starter · #13 ·
update: I noticed when refreshing server lists it comes up with really high pings sometimes or doesnt even list any at all. I have to hit refresh a couple times and it gets down to low pings after that. It looks like its spiking when I refresh the lists but in game I dont see the ping actually spike.
Check to see if Steam is DL something in the back round, that was happening to me today
Discussion Starter · #15 ·
well, theres a ton of DL's that are paused. but not active.
Call your ISP and say you are experiencing "inconsistent network performance" - do not mention games or ping, just say that Google may load very slowly, and then you'll refresh and it'll load quickly, and then refresh again and it's slow...
alright I'll try it, thanks.
The rates should fix it.
If it doesn't, disble NAT(You should ask your isp to do it)
If that doesn't work, call your isp and ask if they can disable interleaving.
I had the same weird lag-kinda-effect
1 - 20 of 28 Posts
