Hello folks!
Just a quick and easy question: is my pump enough for my loop?
I'll have in two weeks this loop (atm only CPU block):
Pump ---> southbridge GPU 220 block ---> single 120mm Radiator --- > CPU Phobya UC-1 Extreme ---> 1° Mofset MVR-40 block ---> 2° Mofset MVR-40 block ---> RAM, EK Dominato 2x block ---> 2x120mm Radiator ---> 1x120 single radiator ---> Reservoir
I'm pretty sure that the pump is enough for that loop because i've seen more complicated loops with the same pump, and i heard that the RAM - Motherboard blocks aren't Restrictive at all as they have a single line running them without any path (except for the GPU-220 block), anyways i'd love to have a confirmation (i hope) from you guys!
Another thing, the real question, when i'll add another 3x120 radiator, plus a GPU block will the pump be enough?
(check my project log for more informations if you wish)
