Is the Lamptron FC5 v2 fan controller still the best around?
Looking at the pricing. The cheapest model (LT) goes for about 85$. Then, we have the pro version at 171$ and finally, the top dog, the XT goes for 229$ and it includes a remote and heatsink.Originally Posted by kevindd992002;13066818
how much is the aquero 5?
Yep. I have been using my FC5v1 for more than a 1yr and it has been all good. I still havent open my free replacement FC5v2 yet.Originally Posted by kevindd992002;13094822
so what's the verdict of many? is the lamptron fc5 v2 still one of the best fan controller out there?
Originally Posted by Gilgamesh9 ![]() Is the F5v2 deep black while the Fc6 is dark grey? http://www.aerocooler.com/products/cp_FANLMFC5_m.jpg http://sgmodder.com/images/7ef677d7f...bde%5B1%5D.jpg ? |
Originally Posted by Gilgamesh9 ![]() so one of the photo is wrong color? Also isnt Fc6 better than FC5v2? and if not why? |
There's no risk having a manual fan controller. The main point of me having a fan controller is to fine tune the acceptable noise level especially in my case where I have two San Ace 38mm fans that are really loud. Once you set the right fan speed that you want, you are pretty much set. In general, ppl having fan controllers is just to have greater control over their fan speed.Originally Posted by Gilgamesh9;13100717
Nice that look almost like a HAF-X case?
Is it correct lamptron Fc5v2/Fc6 does not have automatic mode?
Does it pose a risk for me having a only manual fan controller
if i never controlled fans before?
can some software still overide the lamptron for automatic fan controlling
for those busy moment during games or so?
something i should read before controlling fans manually?
Btw, not sure if i can get FC5v2 here will i stil be fine with a Fc6
i have the HAF-X default 5 200mm fans (but with led) + 1 thermaltake Spinq VT fan
so though of 2 fans be sharing channel.
Raiden can u tell me how did u do it
to share what fans on the haf-x if u have that case?
