1 - 6 of 6 Posts
I need to set up two differn't network connection off one lan port, i need ot be able to disable one and have the other one enabled but when i can enable the other and disable the other.
Discussion Starter #2
ok let me revise this, I need to be able to switch between two network connections, one to my work and one to my home network, how can i acomplish thsi with one network port ?
Discussion Starter #4
sigh, it gets really annoying reytping in each ip and gateway and dns every single time -_-
You can always just set up your home network to the same IP range and subnet as your work IP setup.
Sorry, no. Currently not available.<br />
Well, I guess there is some thing out there, but I know it won't have no spyware.
1 - 6 of 6 Posts
