Make sure you have flashed to BIOS 12-07 and then set up Genie for the memory timings.. Auto settings will not get you too far with the Expert.
Originally Posted by ncsa The Expert BIOS is just not tuned for TCCx and while some may have success there are few who are able to run their modules at DDR600+ as you can on the Ultra-D or older nF4 MBs. Generally you will find that these MBs will like running TCCx at high speeds > 280 (DDR560) 1T but they are good MBs for the new type of modules 1Gb and the older BH/UTT high Voltage modules. |
Originally Posted by ±PinK=FloYd± wat vcore you using? and how much airflow you hav eon your ram? |
