hey guys,
Im new to the site. i just cleaned up the bottom of a $7.00 cooler master heatsink i got today. It came with a terrible finish on the bottom. i took care of that tho.
before:
after:
that was after some wet sanding w/ 400 grit, 1000 grit, 0000 steel wool, then polished with Brasso. took about 15 minutes, im happy with the results.
I got this sink because it uses an 80mm fan so it will be more quiet than the stock AMD cooler.
now i just need to make use of these badboys:
6" inch beasts. 48volt. @ 250 CFM X 6. when in the window they change the air in my room in less than a minute
-George
before:
after:
-George
