A 15° improvement is a bit lofty unless you have an extremely concave/convex HS, however I will never again install a HS without first lapping it. I have seen improvements from 5 to 11° with various lapping projects. In the case of the 11° improvement the HS was noticeably convex and it took for what seemed like forever to get it flat. Yes the procedure is basically the same as lapping a CPU.
