So the family has a Gateway laptop that has had some serious power problems over the past year. When plugged into the AC adapter, the power cuts in and out. A pink like is supposed to glow when the battery is charging; the pink like flashes a couple times every couple seconds, and when it does flash, you can hear a little "zzzzzzzz" sound. This has been going on for a long time, and eventually the laptop refused to power up. When we took it to a repair shop, they said that it was a bad solder joint, and luckily they were able to fix it.
My question is... do you guys think the problem is with the AC adapter and not the laptop itself? Do you think the power cutting in and out is likely to break the solder joint again?
Also, I have another AC adapter for a different laptop around here. Could I use that one to see if the problem is in the AC adapter and not the laptop?
Standard AC Adapter (Gateway):
Input: 100-240V~, 50-60Hz 1.7A (1,7A)
Output: 19V --- 3.42A (3,42A)
Other AC Adapter (Toshiba):
Input: 100-240V ~ 50-60 Hz 1.5A (1,5A)
Output: 19V --- 3.95A (3,95A)
