1 - 4 of 4 Posts
Hello!
Can you please navigate to C:/Windows/Minidump on your mother's laptop and upload the latest dump files here?
To do that, click the little paper clip in the reply box labeled "Attachment".
My apologies, I forgot to mention to zip up the dump file(s)
Alrighty, the faulty device driver is "stdriver32.sys", which belongs to NCH - SoundTap Audio Recorder. You can remove this software by going through the traditional Control Panel>Uninstall Programs list, or you can download a piece of software called Autoruns . Once it's opened, go to the drivers tab, scroll down and find "stdriver32", and then uncheck it from the check box on the left, and then restart.
Let me know if the issue is solved after doing so
DMP file:
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck C2, {41, 88078000, 7e78, 7f669}
Unable to load image stdriver32.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for stdriver32.sys
*** ERROR: Module load completed but symbols could not be loaded for stdriver32.sys
Probably caused by : stdriver32.sys ( stdriver32+4ee4 )
Followup: MachineOwner
1: kd> !analyze -v
BAD_POOL_CALLER (c2)
The current thread is making a bad pool request.  Typically this is at a bad IRQL level or double freeing the same allocation, etc.
Arguments:
Arg1: 00000041, Attempt to free a non-allocated nonpaged pool address
Arg2: 88078000, Starting address
Arg3: 00007e78, physical page frame
Arg4: 0007f669, highest physical page frame
Debugging Details:
BUGCHECK_STR:  0xc2_41
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  DRIVER_FAULT
PROCESS_NAME:  RescueTeam.exe
LAST_CONTROL_TRANSFER:  from 80548c2d to 804f9f43
STACK_TEXT:
a5c3fa30 80548c2d 000000c2 00000041 88078000 nt!KeBugCheckEx+0x1b
a5c3fa70 8054b49a 88078000 00072d28 8a7542e0 nt!MiFreePoolPages+0x8b
a5c3fab0 8054b95f 88078000 00000000 a5c3fad4 nt!ExFreePoolWithTag+0x1ba
a5c3fac0 ba15cee4 88078000 8a754290 8862e7a0 nt!ExFreePool+0xf
WARNING: Stack unwind information not available. Following frames may be wrong.
a5c3fad4 ba15aa0d 00072d28 00000000 00039694 stdriver32+0x4ee4
a5c3faf4 ba15afc1 00000000 00039694 00000000 stdriver32+0x2a0d
a5c3fb1c ba15b498 00000001 804f7e92 a5c3fb6c stdriver32+0x2fc1
a5c3fb2c ba159f3d 00000001 00000000 8a2f6218 stdriver32+0x3498
a5c3fb6c ba15e767 8a64ccc8 a5c3fbd8 804ef19f stdriver32+0x1f3d
a5c3fb78 804ef19f 8a36dba0 8a590e70 8a590e70 stdriver32+0x6767
a5c3fb88 a65f6774 e16bec50 00000000 8a590e70 nt!IopfCallDriver+0x31
a5c3fbd8 a65f92a2 8a590e70 00000000 e13cff08 sysaudio!ForwardIrpNode+0x1b2
a5c3fc30 b8fddf95 883f82c0 8a590e70 a5c3fc64 sysaudio!CPinInstance::PinDispatchIoControl+0x153
a5c3fc40 804ef19f 883f82c0 8a590e70 806e7410 ks!DispatchDeviceIoControl+0x28
a5c3fc50 8057f98e 8a590fb8 880cc6b0 8a590e70 nt!IopfCallDriver+0x31
a5c3fc64 8058081d 883f82c0 8a590e70 880cc6b0 nt!IopSynchronousServiceTail+0x70
a5c3fd00 80579298 000004dc 000001c8 00000000 nt!IopXxxControlFile+0x5c5
a5c3fd34 8054167c 000004dc 000001c8 00000000 nt!NtDeviceIoControlFile+0x2a
a5c3fd34 7c90e514 000004dc 000001c8 00000000 nt!KiFastCallEntry+0xfc
0012efb8 00000000 00000000 00000000 00000000 0x7c90e514
STACK_COMMAND:  kb
FOLLOWUP_IP:
stdriver32+4ee4
ba15cee4 ??              ???
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  stdriver32+4ee4
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: stdriver32
IMAGE_NAME:  stdriver32.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d059370
FAILURE_BUCKET_ID:  0xc2_41_stdriver32+4ee4
1 - 4 of 4 Posts
