What is your maximum budget?
£670
What country are you in?
The United Kingdom
What will be the uses of this laptop?
On-the-go gaming (only games like Left 4 Dead, Magicka and Mincraft)
Do you have brand loyalty or care which brands we select for you?
Nope
What screen size do you require?
13/15" is fine, 17" if you can find one.
What screen resolution do you require?
Preferably 1366x768, as it's the norm nowadays
Are you looking to buy NEW or would refurbished/recertified/used be okay?
Preferably new, but will look at the refurbished options.
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet)
Don't mind too much.
What games would you like to play with your laptop? And on what settings?
Left 4 Dead 2, Maxed out at whatever the laptops native res is, Magicka maxed out, Minecraft maxed out
What operating system do you need? (if any)
Windows 7, but don't mind buying OS separately
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.)
Nope, as long as it's not an ugly laptop (I.e green or teal or something)
How much hard drive space do you need?
Above 200-ish Gb
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.)
A microphone
Is there anything else we need to know?
Preferably from places like Ebuyer.com
£670
The United Kingdom
Nope
Above 200-ish Gb
A microphone
