laptop for unreal tournament 3?
560 Views 9 Replies 7 Participants Last post by  rhkcommander959
Looking for something along the lines of a 7600go / etc that can play the game, and doesnt cost an arm+leg.
Thanks for any helps
1 - 10 of 10 Posts
http://www.newegg.com/Product/Produc...82E16834114644
?, I'm sure it's capable of games, and has a decent processor.
And basically Toshiba Laptops are bullet proof.
the intel 4500 isnt playing ut3 lol
EDIT: http://www.newegg.com/Product/Produc...82E16834152073
that should play it very nicely. I really wanted to get this laptop but it isnt available in the UK. So i got the dell studio 17 with the ATI 3650, which plays ut3 quite nicely, just not at 1440x900
I didn't see the UT3 part
Originally Posted by Tator Tot View Post
Check out these laptops
http://www.newegg.com/Product/Produc...82E16834114631
http://www.newegg.com/Product/Produc...82E16834152086
http://www.newegg.com/Product/Produc...82E16834114606
EDIT: You will need a Mobility HD3650, or an 9600M GT to play UT3 well.
EDIT2: The Geforce 9 series, and ATI HD3/4k GPUs are the ones out right now. No more Gefoce 7 or 8 series.
Played it last night on a 9500m GS and even that ran it real well
Whats your budget?
But not with Eye candy, or a higher Res, like 1650 or 1440.
you might want a laptop with a good gpu that's all you really need
budget is as cheap as possible.
used or new dont matter either!
thanks for the suggestions keep them coming
1 - 10 of 10 Posts
