I have a Toshiba Satellite A215. Recently, the harddrive started to crap out due to my dumb friends leaving it sitting on carpet/my bed/anything that doesn't allow airflow under the laptop. Hence, i had hang up problems that would cause it to randomly go unresponsive.
So when I went to just wipe the system, I couldnt use the install disks because of an error. Toshiba said it was due to the harddrive, as i assumed. They said it might also be the memory.
But anyways, I bought an open item harddrive 160gb 7200rpm harddrive from newegg.
Put it in and it worked great. But after a few days when I got everything installed back on it, it would freeze up overnight. I'd wake up and it would be completely unresponsive, or keep freezing every few seconds that I had to power down and restart.
so I was like whatever, I can wait till summer and diagnose everything. Well now, it hangs up if i leave it for like 2 hours or more. Im thinking its the memory screwing up or something that is causing the comp to have to try to pull everything from the hdd which is causing a hang up. any ideas here?
