1 - 4 of 4 Posts
Why has not msi included the drivers for the webcam?
Wanted to use facerig, but the webcam drivers are nowhere to be found :S
MSI GT72 2QD DOMINATOR
Umm, How Bout Noooooo.
They should be installed by default, if not windows will probably install what is the webcam doing?
What is the webcam model?
Nothing is installed, closest thing to a webcam installed is facerig virtual cam
Windows has not installed anything.
What the cam is doing? no idea, didn't ask.
Lol what is the webcam model. And I mean is it showing up in DM or no? I was looking into your issue and seen others with it saying the drivers are there already but the webcam has a combo key to enable or disable it in DM, FN F6 for other similar MSI lappys so try that.
If it is showing up in DM then does it say there is no driver if so try a windows update. Windows update can and will install drivers without telling you for common devices a Webcam is one of said devices thats most likely why it isn't under MSIs site.
1 - 4 of 4 Posts
