1 - 4 of 4 Posts
There should be a section somewhere (User CP) that allows you to check for the threads you have posted in.
I know you can check for the posts you have made. But there isnt easy access to it.
I myself tend to forget what threads I have made posts in and if they are important its a bummer that I wont post in em again.
Go to User CP / Edit Options / Default Subscription Mode and set it to No Email Notification. That way, any thread you post in will be accessible through your User CP. All subscribed threads with new posts will be highlighted, and you can easily access the subscribed thread that do not have new posts.
Or when your at the homepage where it shows the currently active users you can click your name there then go to show threads started by this user or show all posts by this user.
1 - 4 of 4 Posts
