1 - 12 of 12 Posts
Here is how I plan to setup my loop.
Fans : 4 Medium YLs (push/pull)
Res : EK Multioption Res 150
Pump : Swiftech MCP655-B
Block : Swiftech Apogee GTZ
Rad : Black Ice GTX 240
Res > pump > fan:rad:fan > block > res
Does everything look okay?
yup setup looks good! same way i did mine!
Discussion Starter #6
Originally Posted by Pencuri View Post
You're good to go. The loop set up is correct. Enjoy overclocking that i7 ^_^
I will :] Thanks!
Thanks for checking
Originally Posted by mastical View Post
Cool reservoir. What kind of tubing?
The res is a EK Multioption Reservoir 150. Got it off Sidewinders. Tubing is gonna be white Primochill with some nice black compression fittings :]
Originally Posted by lordikon View Post
How much time did it take you to model all of that?
Approximately an hour. The models are found on a google sketchup "warehouse"
Very nice render, and some great gear to boot!
If the render is to scale, then you may need to raise the pump a wee bit as that angle that needs to bend around the backside of the PSU is kinda tight.
Also bear in mind the cables that will be exiting out the backside of the PSU as well, and may be a hindrance.
Discussion Starter #8
Thanks :]
I think its fairly accurate and I think you're right. However, I just realized my PSU is alot shorter than the 1000W one shown. And I have nothing on the bottom drive bays except the pump. It should give me enough wiggle room to fit the PSU cables through the back and still mount the pump there right?
Wheres your optical and hard drives going? i'd mod the case and top mount the radiator...
Discussion Starter #10
I opted out of optical drives cause I dont really use it. It'll be around and I can just connect it if I ever need to. I have a SSD mounted on the other side of the HD bays. (You can't see it but its where all the cables are hidden)
I thought it was a pretty neat way to hide them :]
Top mount ftw, else you will push all the air out front I like when front takes air in and puts it out at the back and the top
Discussion Starter #12
Do you approve of top mount or are you disagreeing with it?
1 - 12 of 12 Posts
