1 - 5 of 5 Posts
Science
How is it done i have like water marks on it and etc can i just use windex?
They sell wipes... but i just use windex and then finish the corners with pressurized air duster to clean the paper towel bits out of the edge<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
The wipes are from any computer store and they're overpriced<br />
Link<a href="http://www.pixelclean.com/?ref=AdWords&kw=Lcd%20Wipes" target="_blank">http://www.pixelclean.com/?ref=AdWords&kw=Lcd%20Wipes</a>
Don't use windex! Over time it will turn the screen yellow and remove the coatings so it dries and cracks. I just use water and toilet paper. One wet then one dry. Works every time.
they make special spray for it.<br />
<br />
Best buy sells "monster" LCD cleaner...it's what I have...works wonderfully on a fine cloth.
1 - 5 of 5 Posts
