1 - 3 of 3 Posts
Does anyone have this issue when they turn on their monitors? Mine emits this ridiculously loud whine sound that goes away after 10 minutes when i turn it on. Is there a way i can fix this?
Personal experience, not sure if it will help.
Well I share a similar problem with my second monitor, it began after I pull out the power connector out during usage. Now often there is a peep/whine coming out of it. You could try to RMA it during warranty, I have send back a laptop, two PSU's and a HD4850 because of this kind of sound so you'll prob get your approval. If not there is no other choice then let it be, and hope that it goes away with time. (unless your a LCD expert)
Maybe it does not go away after 10 Min, but you adjust yourself to phase out the sound. Hypersensitive hearing sucks, trust me
Good luck
Try adjusting the brightness setting....
Otherwise, you could open it up and apply some hot glue to the coils.
1 - 3 of 3 Posts
