Hay,
I've just ordered myself this little beasty, i'm going to OC it, but i have seen that the Stock cooler is not really up to par shifting heat when its OC'd, especially shifting heat from around the memory.
http://www.leadtek.com/3d_graphic/wi...0_gttdh_1.html
I've look around and i can't see anyone that does cooling for the 7600gt AGP. except for Zalmans.
Wondering if anyone else has had problems with the heat when OCing it, and if you replaced the cooling system what did you use?
Cheers
Cheers
