The fitting above drips once every hour if I have my Swiftech MP655 pump set at "5" (highest setting) but doesn't drip at all after 24+ hours of leak testing with the MP655 set at "1" (lowest setting). I do not plan to ever set the pump above setting "1" so should I drain the loop and fix the leak or let it run and fix it when I flush the system in about 4-6 months?
