21 - 40 of 87 Posts
· Premium Member
Discussion Starter · #21 ·
Originally Posted by frickfrock99 View Post
I've been running around everywhere asking folks this, so I figured I'd give it a shot here.
For one, is the standard live.php feature gone for good?
And the other thing I was curious about was if it was possible to remove the time stamp from the posts in the new "live feed" or at least change the format of it.
http://www.overclock.net/forum/newposts/filter/feed
Live.php in that form is indeed gone, but the same functionality is present (and expanded on) in the activity feed that you've linked. Make sure you've unticked 'Subscriptions Only' and only select 'Forums', and it should just Live.php would have. It has been slow today, but should be getting back to true "live-ness" this evening.
Is there a particular format you're looking for? Generally, the timestamp is useful in a continually updating view to keep track of things moving past.
· Premium Member
Well, I had my fingers crossed for having the poster/time on one side and the actual post itself on the other. Both would be in separate boxes of sorts instead of the current system of the post itself then the poster/line under it.
Reason being, I usually have OCN live open 24/7 on one side of the monitor whenever I work/ hang about. I've found it easier to read that way and it allows to me multitask efficiently. Having the lines stacked on top doesn't allow me to get a full idea of the post/thread at hand, so I have to either expand my window or manually click the post. Any plans on possibly introducing a format like the old style or maybe letting us move those things around?
Other than that, I adore everything else. Nice job.
Where exactly is the "Navigate to the main Groups page."
How can you remove the 'Your Recent Activity' from your profile page? I dont need or want it.
· Premium Member
Originally Posted by Blindrage606 View Post
How about disabling the uber annoying feature of loading the last post instead of the first post when clicking on a thread?
Yes this!!!
Except for this, I think everything is good!
I rather like the new OCN.
· Premium Member
Discussion Starter · #29 ·
Originally Posted by {Unregistered} View Post
Yes this!!!
A fix for this bug is in the works, and should be passing through QA now. We'll get that corrected!
· Premium Member
Discussion Starter · #31 ·
· Premium Member
Originally Posted by Artemus View Post
Where would one post a support ticket at now? I've searched and looked, but with no luck.
If you're looking to file a bug report, this is the right place:
http://www.overclock.net/t/1164277/bug-reporting/0_20
If you just need help with something, a thread in this forum will work.
Remember on the old site where you could submit a ticket for an Overclocked Account and the like? I can't seem to find that anymore. Thanks Chipp for the fast response.
· Premium Member
Discussion Starter · #33 ·
For now, please use an email to [email protected] for that purpose! Thanks!
We'll be updating things with details on our formal replacement for that system soon.
· Premium Member
Thanks again Chipp!
+ Virtual Rep
· Premium Member
Or hit 'preferences' at the bottom or top of every thread and change it in there.
· Lister
Yes this!!!
Well, still no email notification of posts, though there is email notification of PMs.
Photo Galleries still gone.
These are the things that affect my OCN use the most, though I've found my profile keeps track of threads. Since the change the clubs I OP have had a drastic drop in posts, and I suspect that is the lack of email notifications.
· Premium Member
Discussion Starter · #40 ·
Yes this!!!
Please bear with us - ticketed bug fixes are in progress for both missing galleries and email notifications not going out.
21 - 40 of 87 Posts
