Quick question on adding products to the database. I added the SCYTHE Mugen 2 SCMG-2100 but can't seem to figure out how to add details. Got the description, but wanted to add individual details like size/weight, etc. Under the "Details" tab, it isn't allowing me to add anything. I click "New Row" and the only thing I can then change is the "Value" column. The "Detail" column has a drop down list but nothing is in there and you cannot manually add to it. If you try to save with something in the Value box and nothing in the Detail, it will just revert and not add anything. I am probably missing something simple, but this is bugging me that I cannot add any details. Any advice or is this some known issue?
Edit: I noticed all other products, that already have Details added, you can choose from a variety of things in the drop down box in the Detail column. All these options are not available on a new product added. Is there a way to manually add items to the drop down list? As it is now, the only thing you can select is "Choose" in the drop down list for "Detail".
