1 - 9 of 9 Posts
Has anyone used these LED corner-mounts for case lighting? Something like these aluminum channels:
I'd used these for under-counter lighting before. I thought of getting a couple meters of this stuff, and mounting them just inside the case panels. You could mount them with double-sided tape and have the light directed back into the case. And the "lens" should diffuse some of the spotlight effect of an LED strip. I just haven't seen anyone else do it before and I was hoping someone had so I could get an idea what it might look like.
I'd imagine it should work just fine provided you can keep them and the LED strips out of direct sight. I did essentially the same thing with a metal U Tubing and just hammered one side over to make it 45 degrees like that and it worked just fine.
Senioritis Member
Where did you find those extrusions?
Discussion Starter #4
There's a bunch on Amazon, and almost all of the "LED" specific webpage sell them. Just search for "LED corner channel". I've seen the price vary from $15-40 per meter though, depending on if you want bare aluminum or anodized and what type of lens.
Senioritis Member
Thank you very much!
Moderator
You could just get some sheet metal, cut it in to 3/4" - 1" strips and whatever length you need, then fold it at around 1/4" - 3/8" depending on the width of your LED strip. This way you can set it to any angle you want, then just use some 3M heavy duty double-sided tape to secure it in place.
Discussion Starter #7
True, something simple like that would get the 45" mounting. But it wouldn't have the lens to diffuse the LEDs..
I have had a play with this although used a simple U profile and several different diffusers.
In all honesty it was a waste of time - either the diffuser diffused the light too much and you couldn't see it or it wasn't enough and it made practically no difference.
Sitting it at 45° may have better effect
Discussion Starter #9
Well, that's good to know. I'd rather not waste a bunch of time and money for that little of an effect. I can make up a 45deg mounting solution myself pretty easily. The lens was the part that would be hard to do and make it look decent.
1 - 9 of 9 Posts
