1 - 3 of 3 Posts
Hi,
I have a Lenovo Ideapad Y510 and the screen is becoming loose. By this I mean that when I tilt it back past 90 degrees it simply falls over the other side.
Does anyone know how to fix this? (where the screws are located that tighten the screen)
Thanks
Originally Posted by razr7
there should be a couple screws around the screen. look around and screw them back in. if this doesn't work i would take it to a computer repair store
thanks for the help, lol that's the first thing I did, but none of the exposed screws seem to be helping tighten the screen.
Just wondering exactly what I need to do to get to those tightening screws.
1 - 3 of 3 Posts
