If any of you have already removed the ihs, why not do direct die water cooling.
All you need to do is drill a rectangle about 20% larger than the die though a water block.
Than place a large o ring over the die and clamp the water block down 100% evenly on each screw using a torque pattern.
Lots of people did this with the old P4s but i haven't seen it done in a while
Iam sure it would pay off for ivy bridge
