1 - 20 of 66 Posts
I started this build because I needed a HTPC for my media center, and had some core components laying around. I also had an itch to build something:)
I also wanted to play some of my games on my TV ( a 55in Samsung 3D). I had a 295 from my Sniper with a water block to use, so that was part of my decision to water cool, also for low noise. The Lian Li case I am using could not fit everything so I built a radiator box and tried to match it to the Lian Li case.
Now I know this is EXTREME Overkill, but this IS OCN. This thing kind of took on a life of it's own. I have had Great time building this(don't know what to call it) but let me know what you think:) Parts list and lots of pictures.
Parts list:
Lian Li PC-C33B ATX HTPC case
Asus P6T-SE i7-920co w/Heatkiller 3.0
EVGA GTX-480 w/HeatKiller & EVGA back plate(295 died 480 RMA)
Corsair Dom 6GB DDR3-1600
Crucial C300 128GB SSD
W/D 1.5TB Carver Black & W/D 2TB NAS
Seasonic X750w Gold PSU
Lian Li parts, PCI fan controller, 3 side panels, 20in1 card reader, SSD mounting kit, Premium case feet.
Radiator box parts:
Lots of aluminum from Ace hardware
Swiftech MCP655 pump w/speed control
Black Ice GTX Gen2 Xtreme 240 High Perf. Radiator
Panaflo High Perf. 120x38mm fans
BP Water Tank Z-Multi 80 POM
BP D5 Mod Top V2 plus Mod kit Black
BP Compression fittings Black 1/2x3/4
Koolance Quick Disconnect Extreme Flow
Tecnofront Airbox 240 Plexi
XSPC 120 Radstands
Tygon tubing black
MDPC Sleeving and Button head screws
By cd69scorp at 2011-07-24
By cd69scorp at 2011-05-04
By cd69scorp at 2011-04-03
Bottom of rad box.
I am using thin foam weather striping to make a good seal on the rad box.
I used regular fan shrouds to set the Panaflos back a little, kinda like a tunnel.
Had the idea in my head, just wasn't sure how things were going to work yet.
Can you remove the hard drive bays? If you removed them I bet you can fit your 240 rad right there and put the hard drives in the CD bay with some adapters. That way it's all internal.
Honestly, if I tried to fit everything into this case and do what I wanted it to do, I would have had to butcher a beautiful case:(
Discussion Starter · #6 ·
Originally Posted by 7ranslucen7;13841696
subb'd. Always wanted to try an htpc h2o build. looks good so far
Thanks, It gets better.
I wish I had the spare parts laying around that you do. Subbing I want to see this.
Discussion Starter · #8 ·
What I wanted to accomplish is to make this as quiet and efficient as possible and still look good in my media center. I also had to be able to separate each component easily for cleaning and moving.
By using the 38mm Panaflos and Air box on the Black Ice 240 radiator and a Lian Li speed controller, I got a good balance of static pressure almost no sound until I needed the extra cooling.
Still haven't decided the placement of everything, but got some fittings in.
With some of the fittings in figured out where things will go. And started drilling holes and slots.
Discussion Starter · #9 ·
With the reservoir I wanted to raise it up for a more direct flow to the pump. Also mounted radiator assembly and pump on rubber pads.
Now for the frame.
Discussion Starter · #12 ·
I am using a Lian Li PCI fan controller for the two Panaflos. It will turn down the fans to about 800 RPM. I made a bracket to sit next to the fans on the front of the rad box. And it keeps the Lian Li theme going.
Next is the pass through for the tubing using BP Pass through fittings and some large washers that I reamed out for a tight and secure fit.
And know you will get an idea of the lay out and how this will work.
Next is the pass through for the Lian Li case.
Discussion Starter · #14 ·
Originally Posted by Skylock;13846879
Wow this thing is crazy...cant wait to see the end result.
Very nice work:thumb:
Thank you, and yes it is Crazy!!! More pic's coming.
Lol total overkill. But watercooling it is a good idea.... my HTPC gets really hot even after 20 minutes of dirt3. Simmilar case to that one. (Even smaller though)
Discussion Starter · #18 ·
Originally Posted by RoW
Where did you get the aluminium frame for the rad box from? BTW, really nice, and a little bit of overkill
LOL, a little overkill, is an understatement!!! But like I said this is OCN, and this is going to do more then steam movies and videos. As far as where I got the frame, as you can see on page 1 that I made the the frame from aluminum pieces I got from Ace hardware
Discussion Starter · #19 ·
Originally Posted by tlxxxsracer
This looks very good! Well done so far
Love the Lian Li cases
This is my first Lian Li case and I am extremely impressed with the feel and quality of this case, even for a HTPC case.
And thank you!
1 - 20 of 66 Posts
