You are correct about the board getting in the way. I'm not sure the specs on lian li switch you're thinking about substituting.
I can tell you what does work for sure. I dropped a 22mm bulgin in for power, and drilled out the reset hole to accept a 16mm bulgin for the reset.
You can check out the build log in my sig for details.
