1 - 1 of 1 Posts
Lian Li PC-A70FB Full Tower Chassis Black Aluminium
Description:
The black aluminum case from Lian Li PC-A70FB is a big tower case and provides the components very good cooling. The cabinet is equipped with four fans. In the PC-15 can A70FB drives an E-ATX motherboard and plug-in cards with a length of up to 390 mm ??can be installed. At the top are two USB 3.0 ports and two USB 2.0 ports an eSATA port and a headset are located for easy access.
Details:
DetailValue
BindingAccessory
BrandLian Li
EAN4718466997173
FeatureCase Fans: 120 mm: 2 x available/140 mm: 2 x available
/O Connectors: 4 x USB 2.0/audio line-out/microphone/FireWire/eSATA
Motherboards: ATX microATX Extended ATX
LabelLian Li
ManufacturerLian Li
ModelPC-A70FB
MPN4718466997173
PublisherLian Li
SKUmaxTQXLF7
StudioLian Li
TitleLian Li PC-A70FB Full Tower Chassis Black Aluminium
CatalogNumberList - CatalogNumberListElementGELI-278
142.80833333333334
Item Height11.42 inches
Item Length23.03 inches
Item Width8.66 inches
Package Height11.02 inches
Package Length28.27 inches
Package Weight24.82 pounds
Package Width27.36 inches
PartNumber4718466997173
ProductGroupPC Accessory
ProductTypeNameCOMPUTER_COMPONENT
Item Weight18.1 pounds
1 - 1 of 1 Posts
