It's not hard to figure out.
First, go to Lian-Li's website then look at the specs on the B10. It says the depth (or length) of the case is 515mm or 20.2in or 51.5cm.
I installed a 5870 in a Lancool K62 which is 498mm in length and is based off this case and all the new Lian-Li mid-towers. A 5870 fits in something that's 498mm in length, the B10 is 515mm in length, do you think it'll fit?
