1 - 20 of 31 Posts
ok so i'm getting a lian-li and I really like this Pc-60
but I dont know what size the fans are and I really dont like square holes....
but I see the Pc-7... it looks almost I denticle but with no top case fan
good i want to make my top fan .... but I dont know if the Pc-7 has a removeable mobo tray.. can anyone help... O yea and can I put another fan in front
Links
Pc-7
http://www.newegg.com/app/ViewProduc...112-021&depa=1
Pc-60
http://www.newegg.com/app/ViewProduc...112-022&depa=1
can You send me some more detailed links or reviews would be great
I got the PC-6077 myself. The only real differences I can tell between the PC-60 and the PC-6077 are that the 6077 has a front FireWire and microphone port in addition to the 2 USBs, and supports two rear fans. They look similar otherwise. And I can tell you that I am very happy with the 6077, so if you won't miss the ports and don't mind cutting holes to add new fans, then the PC-60 should do you well.
Yep. My 6077 looks fantastic, and the brushed aluminum feels great to the touch. It is very light of course, being aluminum. No sharp edges anywhere, as some cheaper cases have. Airflow is great, and the sliding MB tray is very accessible. I can find no fault with it at all.
Discussion Starter · #8 ·
...hehe I remember when you bought that case vulcan "you fool"
haha wow I was really dumb then
but anyway
I like that fulltower that someone just put up ... its it too tall??
and i need one with out a window.. but I like it cus its just like the pc60 but with more 5.25 drve bays
O and I think that the Pc-7 doesnt have a removeable mobo try ... can anyone tell?
The M/B tray is fixed in the Pc-7.
Yeah, I was having a hard time justifying spending that much money on a case despite the glowing reviews. I'm glad I did, it's worth the extra cash.
Discussion Starter · #11 ·
I think I am going with the Pc-60 ... after I get christmas cash
but yea ... i'm gonna mod the crap outa it
I was really thinking about the full tower of it but it doesnt have a removeable mobo tray
that makes me cry
thanks alot guys for the input
Oh and bye the way that halflife case I have been talking about all year is about to take form in this case
Discussion Starter · #13 ·
I am gonna mod the hell out of it
but... who else makes a solid aluminum case that is just as plain as That lian-li??
and they have a very sleek edge
and who doesnt like the extra 3.25 external drive... it looks cool when you put 3 ccfl switches there lit up
Originally Posted by nayo_450
as i was saying, almost the same case as
the pc-7b, but its $48 cheeper!
Hey i'm just trying 2 save u a little bank,
http://www.newegg.com/app/ViewProduc...117-031&depa=0
It sure looks a lot like a Lian-Li, I'll give you that. It's hard to tell if it has the same brushed aluminum look from the low-res pictures (you can't see it on the Lian-Li pictures either). But otherwise, I would consider this a strong choice for someone unwilling or unable to shell out Lian-Li prices.
Linux Guru
I really only liked the coolermasters
but they are the same price or more than the lian-li
and yes I was considering a Wavemaster Very Very cirtinly till I saw that the lian-li wasnt outa my ballpark
If you can get a Lian Li you have to get it because it is the best for many reasons, just like the new ATI X850 XT it is definately worth the cost..
1 - 20 of 31 Posts
