First of all new around the forums! hi guyz
Introduction on the forums and such =P
however i'm about to upgrade whole PC for single time upgrade,i would highly need help on componets suggestion/pros and cons if any you guyz have to share about it.
a little back ground i'm currently running in QuadQore Q9400 with my old trusted and faithful friend 9800GT list is goes like this
Procc: QuadCore Q9400 2.6Ghz
Ram: 4gb 1333mhz
Hardd: 1T samung
Power supply: 600W
Motherboard: Asus P5QD Turbo
Monitor: 24 Wide inc ViewSonic LED
mouse keyboard and such
this was in upgrade from my old Pentuim4 with the 5200FX card which i held onto 5 years
,then went and bought PC i stated above which already been 4 years.this was in troublesome upgrade since things in my countery cost HELL of alot so its useually in upgrade for each couple of years is how it goes here,not in some few hours work and such :/,however recenatly i got tierd and bursted out from playing all on LOW settings most of the games i play which a mmo called World of tanks and Borderlands and recenatly installed BL2...which im playing with 15-20 FPS normal and useually drops to 5-10 with a little bit crowed and such...how many times playing low on such and the frustrationg i said ENOUGH!used to play on 860 RES but went i tryied 1920 i got addicted to it and i cant go down more then it ya know a person life and such
however went to check on the site to what they could offer me and this what i got:
Procc: Intel Core i7 3770 3.4Ghz s1155 8MB, GPU Core,
Motherboard: Asus P8Z77-V LX s1155 Core i3/i5/i7, Intel Z77, DDR3 XMP, 2xPCI-E, VGA, DVI, HDMI
Ram: G.Skill 4x4GB DDR3 1600Mhz Ripjaws Z Edition Quad Channel CL9-9-9-24
GPU: Asus GTX670 DCII 2GB GDDR5 DX11 2xDVI HDMI DP PCI-E
Hardd: Western Digital Caviar Black 2TB 7200RPM, 64MB, SATA III WD2002FAEX
SSD drive: Kingston HyperX 3K 2.5'' 90GB SSD SATA III
PSU: Corsair TX750M 750W Modular Active PFC 14cm Fan
Cooler: Scythe Mugen 3 CPU Cooler Rev.B
question is would this work?do they suit each other and such i dont want to get it and not to work or somethin i also want it quiet much as i can make it.what you guyz have to say about it?will this be in noticeable upgrade ?since i forgot how it feels like somethin like it,its tough decision would be nice if you guyz can bear with me !
Thank you in advance!
Ram: 4gb 1333mhz
Hardd: 1T samung
Power supply: 600W
