2 questions, first one has pics
So I'm going over all my wiring for my lighting, I'm going to have 2 UV ccfls plugged into a on/off switch mounted at the front of the case. the switch itself has a light up ring on the front etc.... The harness I have allows 1 molex into the power supply and the other into the item you are pugging in. I'm just not 100% sure which of the 3 tabs to connect the 2 yellow wires to.
2nd question, I have a standard logisys ccfl bar, 2 actually that both plug into the same inverter. from there it has the power cord which will plug into the outlet from the switch. The other goes into the pci slot switch/brightness controller. How much of this hardware can i bypass. I have a feeling the inverter is mandatory but how can i get rid of the pci slot control.
