Limiting Bandwith on Router
429 Views 4 Replies 3 Participants Last post by  darksideleader
I have the WRT54G. Is there some way to limit the internet bandwidth each computer can take?
Thanks.
1 - 5 of 5 Posts
What version of the router do you have?
If you have a v1, 2, 3, or 4, you can flash your router to victek's modded tomato firmware which has IP/MAC bandwidth limiting in it.
hmm... i have version 6 anything i can do now?
I believe version 6 is the only version of the entire WRT54G series (including WRT54GS and WRT54GL) that is not supported by any 3rd-party firmware because it uses a completely different chipset.
I'll do some looking around and let you know.
*EDIT
It seems like that was only the case with version 7 - sorry for making you worry
Go here and write "WRT54G" in the router column:
http://dd-wrt.com/site/support/router-database
Find version 6 and follow the link to the wiki.
very nice, thanks a bunch.
1 - 5 of 5 Posts
