1 - 4 of 4 Posts
Hey everyone,
I'm having trouble with a bit of air in the line coming off of my gpu block and going into the second rad. When I tilt the case in the direction that seems like it would move the water where I want it, it retreats back into the gpu block. My setup is a bit unconventional in terms of the res. It's a swiftech micro with what would usually be the fill port being used as the inlet. I have a ball valve coming off of one of the side holes with some tubing. I included a pic for reference. Any suggestions?
Hi there
As above this does looks like low flow and my main suspicion is GPU block is causing low flow, what pump are you running?
Alphacool radiators are not very restrictive, CPU block too is low restriction block
Hope this helps
Thanks, Jura
Overclocker in training
Hi,
Make sure the pumps pwm fan or pump port is not plugged into the mother board which it doesn't look like it is on the bottom anywhere.
Only wire that should be connected is to the molex power and of course the cheat trip connection to fake out the power supply.
1 - 4 of 4 Posts
