So I've decided lap my CPU and perhaps the H60 as well.
I sourced the sandpaper from a different place this time, I was still unable to find anything higher than 1000 grit. So I have settled with the following:
150-320-400-1000 grit, lowest to highest. As I said I'm about to start, so pictures and results will follow. For now I will leave you with my un-lapped idle and load temps.
For reference, the ambient temp is 16c in my room (winter here, duh)
Idle:
Load:
This is overclocked at 4GHz (200x20) with NB at 2.8GHz/1.275v and HT at 2.4Ghz/stock volts.
And here we begin. You can see the marks on the H60, it's not TIM as I've cleaned it with arcticlean prior:
The culprit:
Starting with the 150 grit:
After exposing the copper:
320 grit:
400 grit:
1000 grit:
Finished product:
All back together:
Check out the sandpaper:
Most of that fine dust is copper from the CPU.
My well deserved treat to myself after all the strenuous work
As for temperature improvements, I will be busy curing the paste the next two days, but I have already seen a 1c drop to 24c at idle, with fresh paste. Haven't done any load tests yet, but the ambient is still 16c.
Idle:
Load:
The culprit:
320 grit:
400 grit:
1000 grit:
Finished product:
All back together:
