Has anyone else has issues with IBT/LinX where the results all match but the time elapsed / gigaflop speed does not?
If I leave the board at auto settings, everything matches as it should. If I select any other CPU multiplier in the BIOS, even keying in stock setting, the results will match (and the program will claim it's stable with about the same total time) but the time on about 20% of the lines will be doubled.
I know when it's unstable from insufficient voltage because the time will return 0.000 (again with the proper result), but half the time at stock voltage and speed just doesn't make sense.
I guess the question is what kind of system instability this could be.
