Linux and Windows running together
371 Views 8 Replies 7 Participants Last post by  error10
Hey guys, i want to know how i can run windows and ubuntu together. I know this requirs me to emulate one of the OS but i dont know how to start. Im not sure how to get Vmware or if there are any better alternatives.
1 - 9 of 9 Posts
See the "Never dual boot again!" link in my sig if you want to run Linux in a virtual machine. Alternately you can dual boot.
If you have the HD space, then just dual-boot. Even better, use a separate hard drive for Linux.
aas above. you could install ubuntu within windows to try it out as well but that can be a bad idea...
i used to have linux with windows on a vmware (cause they both run faster than the other way around), until i finally stopped having to turn on the windows machine by replacing all the windows apps with linux equivalents.
thanks! it worked great!
I prefer VirtualBox to do this, it's a real amazing piece of software!
I wrote the guide using VirtualBox because it's free, and VMware Workstation isn't. I personally use VMware Workstation since it has more features, can do dual-core, and I already have a license for it.
1 - 9 of 9 Posts
