1 - 15 of 15 Posts
Are any of you familiar with a possible text recording program which has a capacity of having a customizable look similar to the terminal? Or is it possible to record text in the terminal itself?
Discussion Starter #7
Originally Posted by TFB
Yeah, Open Office...
Open office does not appear to have an ability to create pre-set visualization/effects.
Discussion Starter #9
Originally Posted by nathris
Try typing nano into the terminal
As you might have guessed, i am not an expert linux user, i will definitely attempt your advice shortly.
Originally Posted by MrAMD_Fan
i just do cntl x then enter, then it lets you choose to save it or not.
That works, but correct usage is ctrl-o, so you can save without having to quit.
It doesn't make a lot of sense, but its still a lot better than emacs or vi.
Discussion Starter #15
Would you kindly tell me how to browse file directories and generally locate files in nano if possible.
Never mind, i found out.
1 - 15 of 15 Posts
