1 - 3 of 3 Posts
Hello everyone,
I put back my 965 to 3.8Ghz, I ran 50 passes of LinX and passed all of them. But for some reason I can't pass 30 minutes of Prime95 Blend with 2000mb of ram tested. Any help will be appreciated.
You're memory isn't stable then I would assume. Loosen the timings or increase volts if you aren't already at the manufacturers specs.
Try LinX with more memory tested and it would probably fail.
Also to i find that prime95 needs a little more vcore to pass that LinX or IBT. You might try bumping you vcore up a notch or 2. also i would drop you ram to the lowest that it will run while trying to overclock you cpu. I is a little easier then because you are only messing with one component at a time and then bring you ram up later after you get you cpu where you want it at and stable.
Hope this helps
Also if you could post a screen shot of your memory and spd tab is cpuz
1 - 3 of 3 Posts
