1 - 7 of 7 Posts
Does antifreeze create condensation??<br />
If i had antifreeze really cold like in the -Celius would there be condensation<br />
<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
Anti freeze doesn't freeze hence the name i dont know if the temp will go that low
Anything below ambient would create condensation.
Ambient is room temp
It would have to be much lower than your room temprature to condense the moisture around the coldest parts of your watercooled loop. The antifreeze does not magicly make things sub zero. Its just a formula designed to have a lower freezing point to remain a liquid in harshly cold environments. Unless you chill your liquid in your WC loop somehow to a very low temp (much lower than you room temp) it will never ever condensate.<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #7
So what would be a good temperature to keep it cool and also no condensation?<br />
And thanks for all the help guys<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <br />
<br />
This is my new project that i am making!<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
1 - 7 of 7 Posts
