if you use a high end rad like the Black Ice GTX or the Magicool Elegant 360 (link in sig for performance test including both rads) you can cool all that with just a single 360 rad, which you can mount inside the HAF. the magicool has an integrated reservoir, so no need to worry about getting a seperate one. pump... Laing DDC with aftermarket top or laing D5 known as the swiftech MCP355 and 655 respectively, the 355 performs slightly better but the temp difference will go pretty much unnoticed, as its in the tenths of a degree in most cases. CPU block.. the Heatkiller 3.0 blocks are the current best blocks in the world... if you can find those get one.. otherwise the Swiftech GTZ will do great too... for the GPU's id recommend the Heatkiller 295 block, again, if you can find it, otherwise id go for the koolance one. (its all copper, plated with nickel, so dont worry about it being koolance, it performs well too)
