I just want to kick in that you've got to be careful about what kits you buy. Some of them are absolutely terrible. I suspect that the ones at Petra's tech are pretty good, since they specialize in WC gear, but many kits exist out there that you might think are a good deal but will give you nothing but trouble.
My advice to the OP is to stick a pair of nice gentle typhoons or deltas (if you can handle the noise) onto the H50 rad and see how that goes. If that's not good enough, then you might want to consider water cooling.
I say this because a good custom setup or any decent kit is not cheap. It will cost you a lot more money. If you get a pair of really sweet fans for your H50 and you're still not satisfied, you can just move them onto your rad when you go for WC later.
It just seems like overkill to be considering WC for what probably won't be a huge drop in temps unless you're content to deal with the maintenance we need to perform and the expense of the practice of water cooling a PC.
Edit: And I'll give my vote to Swiftech. They don't let me down too often. Very solid stuff.
