Intro
This is intended to be a list of all of the GTX 780s that have been made. I will be expanding this thread based on feedback, such as overclockability, whether certain models have worse or better RAM, cooling, etc.
I will also try to identify if certain models suffer from coil whine, or other issues like if the manufacturers have downgraded the PCBs. Let me know if there's anything you want me to put in this thread. Also, let me know if any of these models do not come with VRAM or VRM cooling. I will add it in the notes.
Note: It seems like right now that there is a shortage of RAM and that a lot of the GPUs right now are coming with Elpida VRAM rather than the Samsung cards, including many of the "reference" designs.
What to look for in a GPU?
To begin with, if you are water cooling, the most surefire bet is to get a reference seeing that blocks already exist. Otherwise, you'll have to make a decision for a custom PCB based on the best ones available for watercooling and whether there is a waterblock available (unless you plan on using a universal core only waterblock with VRM and VRAM heatsinks).
Things you want in a non-reference GPU:
1. Good cooling: A good custom PCB should keep the temps cooler than stock and relatively quiet. You may be able to make a custom fan profile should you desire, in which case, look for the noise to cooling ratio of the fans.
Blower type coolers like the reference are good for multi-GPU configurations - they exhaust most of the air used to cool out of the case. Axial type coolers typically have 2-3 fans and exhaust some of their air out, but often most of the air back into the case.
Some custom coolers are 3 slot, which can be good for cooling (better temps at lower noise levels), but makes SLI harder and may affect the resale value.
2. VRM and VRAM cooling: A lot of the time, custom PCBs do not have VRM and VRAM cooling. VRMs especially can get extremely hot, hotter than the core even.
3. Quality of VRMs and Voltage Regulators: A lot of manufacturers will use custom parts for these components, which are very important. Certain manufacturers like to market based on the quality of their components.
4. A backplate and/or a brace. Modern GPU coolers are pretty heavy and a backplate or bracer can help prevent the PCB from warping, which may damage the PCB.
5. Overclockability compared to reference. Good cards will have better overclockability (some may be binned). I am unsure of the impact of voltage locking by Nvidia on this (will need to look into this for each custom GPU on a case by case basis). Most custom PCBs come with a small factory overclock, but that's not what we're interested in, it's the overclock that you are likely to realize if you apply additional voltage.
6. If you are going for 3+ GPUs, watercooling is generally preferred due to the heat output. However if you plan on doing so on air, I recommend blower type coolers as the axial type coolers really need to breathe.
Reference Card
This is the GTX 780 reference model. Naturally being the reference model, this would have water blocks. Cooler is identical to the Titans.
Cooling: Blower style, good for a blower, but so-so overall
RAM: Samsung K4G20325F0-FC03
Waterblocks available: Yes
Overclockability: Need more data (I'm hoping to get a range ex: 1,000 MHz - 1,200 MHz for each card). Default voltage lock seems to be 1.162 mV.
Other Notes:
No backplate or bracer
Voltage Controller: OnSemi NCP4206
Below I will list each of the manufacturers in order (let me know in the thread if there's anyone I missed with a custom PCB). Also let me know if any waterblocks come out for a non-reference PCB.
Asus
780 Direct CU II
Cooling: Direct CU II - 1 fan is intake and the other exhausts; there appear to be 2 BIOS profiles, 1 that cools at 14C cooler than reference (same noise as stock fan) and the other that cools at 9C cooler than reference but is 6db quieter) - see (http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_780_Direct_Cu_II_OC/29.html)
Waterblocks available: Not yet
RAM: Samsung K4G20325F0-FC03 (same as reference)
Other Notes:
Could be an issue with multi-GPUs seeing that one fan is an intake and a separate is an exhaust if you stack them tightly (ex: in 3 or 4 way SLI).
Comes with backplate and bracer to prevent warping
Comes with custom VRMs
2 models, 1 with a factory OC (GTX780-DC2OC-3GD5) and 1 at stock (GTX780-DC2-3GD5)
EVGA
GTX 780 ACX SC
Cooling: EVGA ACX Cooler - cools 7C cooler than reference, same fan noise; see (http://www.techpowerup.com/reviews/EVGA/GTX_780_SC_ACX_Cooler/30.html)
Waterblocks available: Yes - reference PCB
Other Notes:
Frontal base plate to prevent warping (http://www.legitreviews.com/images/reviews/2206/evga-gtx780-acx-cooler.jpg)
EVGA has several models, varying from reference to ACX to their high end classified. There is also a "hydro copper" variant of this card offered.
GTX 780 Classified
Cooling: EVGA ACX Cooler - probably comparable to the ACX model
RAM: Elpida
Waterblocks available: ?
Overclockability: Need more data, but early on could achieve 1,400 MHz+ on air (http://www.overclock.net/t/1408710/cl-evga-gtx-780-classified-gets-overclocked-to-1410-mhz-on-air/0_100)
Reports seem to be wide, some models have a hard time making 1,200 MHz, to others than can clear 1,300 MHz.
Other Notes:
Custom PCB
Appears to have a custom phase design as well
Front plate present to prevent PCB warpage
It's a bit taller than the conventional PCB, so if you are using an SFF PC, make sure that you have clearance
There have been a few issues with this card:
http://www.evga.com/forums/tm.aspx?m=1998536&mpage=1
Gainward
GTX 780 Phantom "GLH"
Cooling: Gainward Phantom Cooler - looking for data
RAM: ?
Other Notes:
I'm looking for reviews of this card
3 Slot cooler design
Not passively cooled:
http://www.tomshardware.com/news/Gainward-GTX-780-Phantom-GLH,23223.html
Gainward claims that it has an 8 phase design an DrMOS, so it looks like a custom PCB
http://www.gainward.com/main/edm/GTX780_Phantom_GLH/gw_edm_GTX780_phantom_GLH.php
Galaxy
GTX780 GC
Cooling: Galaxy GeForce GC
RAM: ?
Other Notes:
http://www.galaxytech.com/__EN_GB__/Product2/ProductDetail?proID=457&isStop=0
GALAXY GeForce GTX 780 HOF Edition
Cooling: Galaxy GeForce GC cooler? Looks different than the others
RAM: Elpida
Waterblocks available: ? Custom PCB, so maybe not
Overclockability: Need more data, but 1,300 MHz seems to be achievable
Other Notes:
Pre-release info here: (http://wccftech.com/galaxy-geforce-gtx-780-hof-edition-gpu/)
Appears to be a custom PCB - (
I'm a bit concerned looking at that cooler - it's pretty heavy and warping could be a concern
8 + 2 phase design (not sure what the models are but there's 8 Panasonic tantalum's for the core and 4 KEMET versions)
Comes with 6 Magnachip MDU3606 Mosfets
CHiL CHL8318 controller
Review here:
http://www.hardocp.com/article/2013/08/14/galaxy_geforce_gtx_780_hof_edition_review/1
On the whole though, this is a very nice card and could very well give the top contenders some competition.
Gigabyte
Windforce 780 OC
Cooling: Windforce cooler; 13C cooler than reference, 1db quieter (http://www.guru3d.com/articles_pages/gigabyte_geforce_gtx_780_windforce_oc_review,8.html)
Other Notes:
Appears to be reference PCB
Comes with bracer to prevent warping
Inno3D
iChill GeForce GTX 780 HerculeZ X3 Ultra
Cooling: HerculeZ x3 cooler (need comparisons to stock see here though: http://us.hardware.info/reviews/4460/5/inno3d-ichill-geforce-gtx-780-review-almost-a-titan!-cooling-and-noise-levels)
Other Notes:
3 slot cooler
iChill GTX 780 Accelero Hybrid
Cooling: iChill Accelero Hybrid LCS - need a review to compare
Waterblocks available: Yes - reference PCB, although it comes with a CLC anyways
Other Notes:
CLC water cooled GPU core
MSI
GTX 780 Gaming Edition
Cooling: Twin Frozr IV Cooling
Other Notes:
Reference PCB
Comes with bracer to prevent PCB warping (http://www.techpowerup.com/reviews/MSI/GTX_780_TF_Gaming/images/card2.jpg)
GTX 780 Lightning
Cooling: Tri Frozr Cooling
RAM: Elpida
Waterblocks available: No - supposedly MSI is going to be releasing though
Overclockability: Right now pretty early to decide, but it looks tied right now with the EVGA Classified and the Galaxy HOF edition; scores from 1250-1400 MHz depending on voltage
Other Notes:
Custom PCB
2.5 slots with "GPU reactor" and large cooler
Does have bracer to prevent warping
Palit
GTX 780 Super JetStream
Looking for a PCB picture
Cooling: Jetstream cooling (15C cooler and 2db quieter under load http://www.guru3d.com/articles_pages/palit_geforce_gtx_780_super_jetstream_review,8.html)
Other sides with OC disagree see:
http://hexus.net/tech/reviews/graphics/57437-palit-geforce-gtx-780-super-jetstream/?page=10
RAM: ?
Other Notes:
3 slot cooler
Custom PCB with 8 phase DrMOS
Not sure if this model has anything to prevent warping
Zotac
GTX 780 AMP Edition
Cooling: Zotac Triple Silencer cooler
RAM: ?
Other Notes:
Not too sure if this is reference PCB or not
Review:
http://us.hardware.info/reviews/4718/zotac-geforce-gtx-780-amp!-edition-review
Buying Guide
Right now among the cards, I would go with
High performance Overclocking
Galaxy GTX 780 HOF Edition
EVGA GTX 780 Classified
MSI GTX 780n Lightning
The Galaxy one especially is claimed to not cost much more than the stock one, so it's a good buy.
I don't know the RAM module yet on the Galaxy card, but if they're not using Elpida, then I would expect Galaxy to be the stronger overclocker.
It looks like MSI, the Galaxy HOF, and EVGA all have Elpida RAM. Price wise, the MSI one is going substantially above MSRP, but with EVGA you'll likely have to get EVBOT anyways, so it's hard to say. The Galaxy seems to be the cheapest of the 3.
In terms of raw overclocking performance right now, it does not seem like any card has a huge advantage over the other one. We still need to see a BIOS from MSI with the full 300%+ power limit and a full voltage OC though. I suspect though that most cards will be in the ~1,300 MHz range. YMMV depending on your luck with the silicon lottery.
Hopefully MSI gets that waterblock released soon though. The only other thing I think may be worth mentioning is that the Galaxy as indicated doesn't seem to have anything to prevent warping. That said, the MSI card is warping slightly under the weight of the cooler.
Quiet Operation
MSI GTX 780 Gaming
Asus GTX 780 Direct CU II
EVGA GTX 780 ACX
I should mention that people generally have regard EVGA's customer support well and Asus not so well in the customer support department. MSI is generally pretty good, although I have heard of a few slip-ups here and there.
Also, if you want quiet operation, you can make your own custom fan profile.
Just Gaming
Otherwise, if you're just gaming and have little desire to OC, then just go with the manufacturer that sells cheapest. I would consider the history of the manufacturer and their willingness to honor warranties though, so perhaps buy the cheapest that offers a good history of customer service.
Other info
I'm expecting to see custom PCBs from Colorful, ZOTAC, KFA, Point of View, and a few others.
I would also like to know what you would like added to this thread.
Reference Card
Other Notes:
Asus
780 Direct CU II
Other Notes:
EVGA
GTX 780 ACX SC
Other Notes:
GTX 780 Classified
RAM: Elpida
Other Notes:
Custom PCB
Gainward
RAM: ?
Other Notes:
Galaxy
GTX780 GC
RAM: ?
Other Notes:
RAM: Elpida
Other Notes:
Review here:
Gigabyte
Windforce 780 OC
Other Notes:
Inno3D
Other Notes:
3 slot cooler
Other Notes:
MSI
Other Notes:
Reference PCB
GTX 780 Lightning
RAM: Elpida
Other Notes:
Custom PCB
Palit
RAM: ?
Other Notes:
3 slot cooler
Zotac
GTX 780 AMP Edition
RAM: ?
Other Notes:
Review:
Buying Guide
Quiet Operation
MSI GTX 780 Gaming
EVGA GTX 780 ACX
Just Gaming
Other info
