1 - 11 of 11 Posts
Hey guys, I just started leak testing my system and I see a few little bubbles moving around my system. I got rid of all the major bubbles, but the pump seems to be running a little louder now and I don't know if an air pocket is trapped in there or something. It seems to be running good with no leaks so far so I was just wondering if that's just how it is. I'm running just distilled water btw, with an MCP655 pump.
Leak testing is personal opinion, I usually run 24hrs, or a tad more if theres still air in the system. Lightly tapping the tubes, shaking the rad, and tilting the case will help speed up the bleed process.
Back to Building
Yeah the bubbles eventually just worked themselves out of my loop. Took about a day, maybe a bit more
The Newt in Overclock.net
I never leak test. Just triple check everything.
Fire it up and sit ready to kill the power.
Never had a leak and I tear this thing apart quite frequently.
If the 655 is the variable speed model, turn the speed all the way down, then ramp it up for a few seconds, then drop it back down. that helps dislodge air in the radiator for me.
Also, giving the system a good shake while it's running. Just make sure your PCI-e cards are very secure.
The air bubbles will take a few days to fully get worked out.
*edit* oops, looks like U solved it
Discussion Starter · #11 ·
This is my first loop so I knew I was gonna leak test for a while before I had enough confidence to mount it but it's been running for a few hours now with no leaks, bubbles working themselves out and I'm starting to get REAL excited lol. I'll wait till after my racquetball game to at least give it a few more hours of consistent running and mount it up. Then snap a few pics and post them up!
1 - 11 of 11 Posts
