REVIEW OF LOGITECH G402 HYPERION FURY
I will be reviewing the new G402 by Logitech, the official successor of the G400s.
http://imgur.com/BT1yJwW
I'd like to give one information straight away: I have been involved in the development process of this mouse by working with Logitech under NDA helping to test Hyperion Fury. That's also why I already have a sample to review. I will go into more detail when discussing the sensor performance and Fusion Engine.
I want to note though that it was made very clear to me that Logitech does not want to have any editorial rights to any of my reviews because they want me to be as objective as possible.
Boxing
The box is very similar to the G502 box, but you can't open the front panel. It's a rather small box.
What's included:
- Logitech G402
- Warranty
- Manual
Box:
http://imgur.com/f4pIugc
http://imgur.com/EdGbL3z
http://imgur.com/WidlwCE
Weight & Shape
While the mouse doesn't look like a G400 at first glance it actually feels quite similar in my hand. The right side lip is also still there, albeit a bit different this time. Some people stated it looks like a R.A.T. mouse, but I can assure you it doesn't feel like one. It's a closed body, I can't even feel the shiny lines part on the upper shell when using the mouse.
Weight: 103 g (without cable)
Height: 41 mm
Width: 72 mm
Estimated width at grip position: 63 mm
Length: 136 mm
Number of buttons: 8
http://imgur.com/88sreGm
http://imgur.com/PTJjYMh
http://imgur.com/L4foevD
http://imgur.com/ukh6k7B
http://imgur.com/9QhA0ac
http://imgur.com/8b1Iyig
A comparison with other mice, left to right: Logitech G100s, G502, G402, G400, FK1
http://imgur.com/tpyIfMt
Now some pictures how I hold the mouse (I'd describe it as a hybrid of claw-palm)
http://imgur.com/5jfJu2G
http://imgur.com/aGQXxQD
And a look at the position of the sniper button. Hard to see, but for me it is in the perfect spot, it would be easy to actuate if I wanted to. However I never use more than one side button for gaming anyway and have even less need for a sniper button, so I never used it. It didn't bother me at all though, it's not in the way of my grip in any way.
http://imgur.com/AMJZsPv
For comparison: My hand is around 19.5 cm from the tip of my middle finger to the base.
To me the shape is nice, but it bears the same problems I had with the G400 (right side lip). There is more space for the pinky now though, so if you use a more relaxed palm grip and/or three fingers on top it would be less of an issue than with the G400.
Of course shape is completely individual preference, so everyone has to try for himself in the end. The perfect shape for me might be horrible for others. So please keep the pictures of my grip in mind for comparison.
Sensor / Performance
Now things get interesting (at least for me) because Logitech once again did something innovative with the new G402. They used a accelerometer/gyrometer to pick up movement when the sensor fails at higher speeds. The sensor used in the G402 is the same used in the G100s (AM010) which always felt very nice to me but unfortunately would lose tracking at about 2.7 m/s. This would be enough for most people, but at my low sens I regularly reach speeds above 3.5 m/s.
Being a sceptical person I would not trust this method if I heard of it before using such a mouse (I had/have no idea how accurate those accelerometers are really) but luckily when I first tested the mouse I didn't feel a difference at all. If I weren't told the accelerometer picks up when the sensor fails I would have never realised it. So in short: it works, and it works really really well.
You can see the point when the Fusion Engine (Logitech's name for the accelerometer technology) takes over in my MouseTester screens if you look closely at just below the 3 m/s marks. The counts divert a bit before that point, after that it's one straight line. Logitech will probably release more information about Fusion Engine in the future, so stay tuned for that.
Now normally I would list malfunction speeds etc, but fact is: it does not malfunction at all. There is a neat little feature in the new LGS where you can try to reach max speeds with the Fusion Engine, I maxed out at 6.5 m/s. For more speeds I would need a bigger mousepad I guess, but it's not like anyone every would need that. I know that someone with a deskpad reached above 9 m/s though.
The sensor is adjustable in steps of 80 CPI from 240 to 4000 CPI, I did only test 400, 800, 1600 and 4000 CPI though. (Standard out of the box is: 400, 800, 1600, 3200)
http://imgur.com/GLtfE4D
As you can see there is little to no jitter at 400, 800 and 1600 CPI. 4000 CPI has a lot of it though.
Acceleration Test
There is accel, but at least it is consistent. Not a big deal imo.
EDIT: as this seems to confuse a lot of people, here is another accel test where I still go fast to the right but not as slow back. So the minor inaccuracy seems to have been while moving very slow
This looks perfectly fine to me. Here is the MouseTester screen for the first fast swipe to the right too.
Lift Off Distance
Between 1 and 2 CD on black cloth, being closer to 1 CD. It's generally very low.
Buttons / Switches / Scroll Wheel
The G402 shares the button design with the G502, so they also feel very nice. The buttons being seperated from the shell really makes for a very nice click feel. The switches are Omrons for LMB and RMB, all other buttons are TTC switches, at least on my version. This might be an earlier model, so this is not 100% confirmed.
http://imgur.com/XJKPztC
The scroll wheel is really great to me, nothing like the big clunky thing on the G502. It is light and crisp.
Build Quality
What you expect from Logitech, very high quality, nothing flimsy. The cable is non-braided (huge plus for me) and a bit too stiff for my taste. If you take a look at the inside of the mouse you can see that everyhing is very well put together, no cheap connections there. Kudos to Logitech for producing quality there.
Conclusion
I like the G402, and for everyone who liked the G400 shape it is definitely a very good option. I'm also impressed at how good the Fusion Engine works. Come to think about it this technology could make older tech more usefull again, like the MLT04 with its only negative being a much too low PCS. I don't know why Logitech went this way and did not chose the 3366 in this mouse too, but even if it is an experiment: it worked. To me there is no downside to the G402's performance with that of the G502. Maybe "cursor-feeling-enthusiasts" have different opinions there, we'll see once more people got their hands on the G402.
Boxing
What's included:
- Logitech G402
- Warranty
- Manual
Box:
Weight & Shape
Height: 41 mm
Width: 72 mm
Length: 136 mm
ALL TESTS ARE PERFORMED ON THE QPAD UC 50!
The real dpi for each setting can be seen in the mouse tester print. As always I also measured the real CPI values and to no surprise Logitech delivered an accurate result as usual with them.
400 cpi, 1000 Hz
http://imgur.com/3BSNK9m
800 cpi, 1000 Hz
http://imgur.com/y2St2kL
1600 cpi, 1000 Hz
http://imgur.com/yWMeJGk
4000 cpi, 1000 Hz
http://imgur.com/JdamjjA
400 cpi, 500 Hz
http://imgur.com/Paj9qod
800 cpi, 500 Hz
http://imgur.com/GmTl91S
1600 cpi, 500 Hz
http://imgur.com/FUuFDBw
4000 cpi, 500 Hz
http://imgur.com/xm40boV
CPI steps
http://imgur.com/wEryMQZ
400 cpi, 1000 Hz
800 cpi, 1000 Hz
1600 cpi, 1000 Hz
4000 cpi, 1000 Hz
400 cpi, 500 Hz
800 cpi, 500 Hz
1600 cpi, 500 Hz
4000 cpi, 500 Hz
CPI steps
Acceleration Test
Lift Off Distance
Build Quality
Conclusion
