Quick questions on this mouse hopefully someone can answer:
1. Are the side buttons default to 1-12 on the keyboard or must they be set through use of the logitech software?
2. Can modifiries be used like shift, ctrl, and ctrl + shift?
3. How wide is it compared to the Razer Naga? According to measurements, it should be only .5 cm wider but is that really it?
4. To the owners of the white version, does it get dirty?
I'm thinking of selling my RMA razer naga 2012 and buying the G600, since it's much more durable I hear.
