1 - 5 of 5 Posts
Just Spent a few hours sanding off the paint on the edges of all my keys on my Logitech G910, it is nothing special but I was happy with the out come, so decided to share. (still need to get some higher grit sandpaper to smooth out some marks from the 600grit)
looks nice, Might consider doing the same thing to mine.
Discussion Starter #3 (Edited)
Thank you, If it helps I used wet and dry 600grit sandpaper with water on the key and sanded all the sides first then sanded round the corners as they seem a little more weak.
The keys feel a little more sharp around the top edge then before, when running your fingers across the keyboard, but i think I can smooth it all down by going with some 1200 over them.
1 - 5 of 5 Posts
