1 - 8 of 8 Posts
Ok i just got my hard drive back from RMA and i reinstalled everything. So i installed the Radium Vista Pack theme thing. And now i dont have a logon screen. It looks like the windows 2000 logon where u type in the user name.<br>
Any suggestions?
Perhaps try:<br />
Control Panel > User Accounts > Change the way users log on or off > check Use the Welcome Screen
Use the classic logon screen<br />
To temporarily use the classic logon screen, press CTRL+ALT+DEL two times on the Welcome logon screen.<br />
<br />
To configure Windows XP to use the classic logon and shutdown screens for every logon session, follow these steps:1. Click Start, and then click Control Panel. <br />
2. Double-click User Accounts. <br />
3. Click Change the way users log on or off. <br />
4. Clear the Use the Welcome screen check box. <br />
<br />
<br />
___<br />
<br />
you are using the classic login screen to fix it follow the steps but put the check in the box dont take it out.<br />
<br />
per- <a href="http://support.microsoft.com/kb/291559/" target="_blank">http://support.microsoft.com/kb/291559/</a><br />
<br />
mattlb0619<br />
<br />
EDIT:<br />
<br />
more reference<br />
<br />
<a href="http://www.windowsnetworking.com/articles_tutorials/wxpplgon.html" target="_blank">http://www.windowsnetworking.com/art.../wxpplgon.html</a>
Reactions: SiPex
Discussion Starter #5
OK well i found that, but when i go into it something comes up and says " Client Services for NetWare has disabled the Welome screen and Fast User Switching. To restore these features, you must uninstall Client Services for NetWare."<br>
I have no idea what netware is, but it seems like it was something installed with the radium vista pack. What should i do?
uninstall it and see if you can change it.
Discussion Starter #7
didnt work. <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
that should have worked, try sys restore ....
1 - 8 of 8 Posts
