I just realized that I set up my h50 a week ago with the incorrect plastic inserts
There are two sets of plastic inserts that come with them... and for AM3 there's the ones with just one hole to choose from. I installed my AM3 setup with the two-hole plastic insert, using the farthest hole from the actual CPU.
My temps are all fine. Lol. Actually I ended up using 2 of the AM3 plastic inserts, and 2 of the other plastic inserts. :-/
Hopefully the thing doesn't fall off xD. I didn't notice a difference when I went to set it up, it holds tight, and my temps at 3.8GHz (and even 4GHz) aren't exceeding 45 celcius max.
Wondering if someone else made this mistake also? The 8 plastic inserts that come with it all look so similar.
