1 - 20 of 26 Posts
Discussion Starter · #1 · (Edited)
This started as a build for my son 2 years ago. At the time I thought he was too young to have a PC. So I slowly started buying parts for him that we're not going to be obsolete. I started out buying a EVGA power supply and a Corsair case. I was assuming that I was going to be able to build the PC within the next year. Now that he's gotten old enough to have one, I decided to go for it since it's Christmas and right now a lot of the parts I got were on sale. Here's the list of parts I've compiled so far.
Lian Li 011 Dynamic
Corsair Air 540 case
EVGA Supernova 850 G2
ASUS Prime z390-A
Corsair H150i Pro XT RGB
Corsair H100i Platinum
Intel i5-9600k
9x Corsair QL white fans 120mm
Corsair ML 120 Pro RGB 3 Pack w/ lighting node pro
Corsair ML 140 Pro RGB
Corsair Vengeance RGB 16gb
Corsair K65 mini keyboard
Corsair M65 mouse
Corsair Void Pro headset
Samsung Pro M.2 NVMe V Nand SSD 512gb
EVGA RTX 2070
Windows 10 Home 64bit
Acer 24 inch XB241H bmipr G-sync 144hz monitor
2511710
PSU install and fan change.
Motherboard install along with Samsung M.2 and Corsair Vengeance RGB RAM.
Discussion Starter · #6 ·
i5 9600k install along with Corsair pump. Did some wiring also.
That's pretty nice for a "first rig"!
I remember my first rig was a destroyed Dell until I mowed grass for a summer to buy a 4000+ brisbane/8800GT and thought I was awesome *****.
Thanks. My first rigs were the same, small, cheap etc... Im going a little beyond for him.
· Mr.4way SLI
Discussion Starter · #14 ·
EVGA GTX 1070 FTW DT install and some more wiring. Did some cable management also.
Discussion Starter · #17 ·
A little house cleaning. Installed the commander pro. Power going to the three front intake fans, and rear exhaust fan from commander pro. The H100i platinum is controlling the fans on the radiator. The LEDs are all controlled by the LED hub which I mounted to the top of the case.
Nice job on the good looking Rig.
1 - 20 of 26 Posts
